Steve Brookes
Moderator
I wondered how long it would be before I get a HVAC problem but now I finally have!
My cabin fans work perfectly if I turn the thermostat control to cold (blue dot) but as soon as I try and turn up the temp they stop.
Found this about cabin fans stopping in the FAQ section on the 964UK.com website:
'The most common cause for this is the rear blower not running. The Climate Control Unit in the dash monitors the air flow and if there is insufficient air pressure from the rear blower the cabin fans will be switched off. The rear blower has a dedicated 30 amp fuse (uprated from the original 25 amp part with no other changes in 1990) in the rear electrical panel together with a relay. The relay used is identical to the one (or two) fitted in the main electrical panel in the luggage compartment for the oil cooler and air conditioning condenser fans. The relays can be swapped for diagnosis purposes.'
Is this where I should start diagnosing the problem or might it be something else?
