No hot air 993 C4
majorporsche
Worked normally until recently but now its over 15mins til hot air comes from the vents despite being set to hot. Any ideas whats the problem ?
Check the rear blower in the engine bay is working as if this doesnt run the ccu will cut the front fans when heat is switched up, check the fuse in the engine bay and also the relay for sticking as mine stuck the other day which left the rear blower on permentatly even with the ignition off. My heating was also intermittent on the journey leading up to it sticking on, it would work for a while then fan pressure would drop, then come back again etc...
