starboard147
Help!! Just rebuilt the back end following an RMS replacement. Turned over the engine with the DME out - no oil pressure! Noticed nose of car was high so levelled it out - then got oil pressure briefly before it dropped to zero... Front pulley bolt had come loose so retightened it (I had used it to lock engine to loosen/tighten clutch and flywheel bolts so must have loosened). Still no oil pressure!!! I've got oil, the pulley is tight. I've pulled the filter and the 'priming' hole is full of oil. Was advised to check indication system by grounding sender terminals one at a time - was told to expect to see warning light to come on for one and max reading for the other. Well, I get the warning light with both and no significant deflection on the needle with either (it just flickers, slightly more for the spade than the ring terminal).
Question - does that indicate a problem with the oil pressure indication system???? I can't seem to find anything in the manuals, in Clarks, Haynes, etc on the pressure indication system, and the cct diags aren't that much help. Does anyone know how to check it?
