No oilpresure when starting cold engine
- Thread starter Guest
peanut
I would change the oil filter if you haven't aleady done so just in case it is blocked . Replace the sender .Check the tightness of the front crank nut then I would find a point where you can plumb in a mechanical oil pressure guage to do a check on the actual oil pressure and time to reach 5 bars
Hilux
Someone (possibly Bert Gear) said on a forum somewhere that there is a drain down one way plug that might be stuck???
It was Jon Mitchell see here
peanut
I would start by tracing the oil flow to the top end on a schematic to see if you can spot any potential blockage points. You may well have a partial blockage caused by some contaminant like silicon or hermatite . Silicon is a curse to engines and frequently gets used when a gasket isn't to hand.When applied and the part is tightened down It squuezes out into the oil and waterways and then travels round until it gets wedged somewhere narrow, restricting the flow. Have you had any new parts fitted in the past 6 months or so ?
Another likely source is a leaky gasket or seal somewhere which is letting by but then you would expect your pressure to be well down say 3 bars cold. If it reaches 5 bars then its probably a partial blockage problem .
Another possibly is a faulty oil pump but that would tend to happen slowly over months not all of a sudden unless your crank damper bolt has loosened. Worth re-torquing that to eliminate that.
I would be tempted to drain the oil and flush the engine with a flushing oil. Remove the filter , sieve the oil and inspect and tear open the filter and check for any trace of contaminants. If none found then you have eliminated a potential problem source and an oil and filter change is cheap and good for your lump anyway
An easy one to check and fix anyway.
Sorry Peanut - just noticed you have already mentioned that... teach me to read things properly won't it[
