szklarek
I noticed the air conditioning compressor clutch wasn't working (ie not engaging) when the a/c was switched on. The lights on the CCU appear as normal when the a/c is switched on and there is the usual change in fan speed when the a/c 'boost' button is depressed. I've checked the power line right by the compressor clutch and, when the a/c is on, there is no voltage. So either the CCU is not delivering the voltage or a fuse or relay has gone (or wiring damage perhaps) - looking at the list of fuses and relays listed on the fuse box lid (in the boot) there isn't one specifically listed for the compressor clutch. Are there any fuses/relays elsewhere and/or has anyone gone any other suggestions? (Tomorrow I will try applying power directly to the clutch but I'll need to disconnect the power feed first to ensure that, if there is a problem upstream in the wiring, I don't make matters worse!)
Kind regards
Anton
Kind regards
Anton
