In case anyone is interested the problem was with my Spark Box (Bosch CDi Unit). I found a contact for repairing the original unit as follows:
http://www.911-hkz.de/
Google can translate the page if required.
The Engineer is Lutz Gerberding, and he seems extremely knowledgeable about these and other units associated with our cars. Lutz speaks good English if you want to email etc.
After looking at my spark box he emailed me as follows:
"your cdi-unit has been repaired and will be shipped back today.
The ignition capacitor (that holds the 400V ignition energy) was defective with a shortcut. The shortcut has blown several other components, that deliver the 400V high voltage.
There are 3 major reasons for a problem like this:
1. Usage of a newer ignition coil type Bosch 0221121001 with silver housing, Made in Brazil , charge number 908 on the bottom side. Use the Made in Germany historic original instead (black housing) or use BERU ZS-109 (without a resistor in series).
2. Burned noise suppression resistors (spark plug connectors, distributor finger, plugs on the distributor cap, plug on the ignition coil). The resistance of this components should not exceed 6000 Ohm, each.
3. Any other breaks in the secondary ignition system, like broken ignition cords, loose spark plug connectors, "¦
In all these cases the ignition energy can´t flow over the spark plug and hits back into the cdi-unit instead. After this has happened a few times, the ignition capacitor will fail.
So the repaired cdi-unit comes with an integrated overvoltage suppressor, but this only protects the cdi unit and doesn´t solve the problem.
If you can´t find any reason that was responsible for the problem, don´t worry to use the repaired cdi-unit. Then watch out for any sparks on the top of the ignition coil (don´t touch anything). If you can notice sparks, the problem is still not solved."
He returned the unit to me in 2days, cost Euro260. Well recommended.
