peanut
has anyone experienced this fault and found the culpret ?
Everything checks out ok spark fuel delivery etc but the voltage at the injector connections is scarcely 1v+ ?
Voltage at DME terminal 30 is 12v+
When i jumper the DME terminals 30 -87 -87b the pump runs normally and the engine coughs a couple of times but doesn't start.
Is there possibly a problem with the ECU ? maybe it is not earthing the injectors properly ?
any ideas are welcome . Its my only transport at the moment and it hasn't run for a month
