berg944
Driving home in my turbo though town my throttle died
It was as if the cable had broken, the car did not cut out but went on to a rough idle!
When I gently pressed the accelerator the idle almost cut out.
I limped into a car park in first gear on idle.
I put my foot to the floor a couple of times but nothing
Then after about 4 min. from the problem starting I put my foot to the floor and the revs came back and idle went smooth.
Swithched off, had a look under the bonnet, nothing obvious
Started OK and drove 3 miles home.
I have only done a couple of thousand miles in the turbo and so far the only work on the engine has been oil and filter change.
Can anybody suggest what could cause this?
