Noise at low speed
- Thread starter idc1873
Ian.
1987 3.2 Targa.
ClubSport 911
The most common suggestion is that one of the layshafts in the gearbox is torsionally winding up, and in doing so allowing the gears to chatter. Another one is that the coffee grinding sound is the result of the limited slip diff (if fitted). The box as fitted to the 2WD version of of the 964 has also been known to make this noise so I wouldn't worry unduly.
Regarding oil for the G50, I have used Swepco 201 in mine for the last couple of years, and it really does improve the shifting - especially from cold.
911addict
Often miss those charming and reassuring sounds when in my 964 turbo - that's progress for you!
