My new C4S Cab (MY2004) has PCM2 fitted and it seems to me that the CD drive in the top of the unit is making a worrying noise.
At first I thought the noise was coming from the AC vent directly the above the PCM as the noise sounds like a duff fan or something in the vent, a kind of fast ticking noise. However, the noise stops after a short while. I removed my hardtop this weekend in preperation for some audio work to be carried out this coming week and on opening the door to get in with the soft top down the noise started as I climbed in. No engine running or key in ignition so that ruled out the fan. After it stopped I ejected the Nav disc and the noise started up again and continued without the disk being in place. It again stopped, I inserted the disc and once again it ticked away for about 15 seconds and stopped.
Anyone else had this. All seems ok in the operation of the PCM (apart from the fact the disc looks like the entire cast of Holiday on Ice had been practicing on the disc!).
RB
C4S (54) Cab in Seal Grey with PSE
RB
