Noise from PCCBs
- Thread starter AndrewCS
Car has just been serviced and green dot against brake condition on the service report.
25k miles.
Tried repeated hard braking from highish speeds in case glazed but the noise persists.
Has anybody else had this please?
Unfortunately I’m not sure that there’s much more you can do without stripping the brakes for further investigation.
Maybe as an initial step you can jack-up each wheel and give it a spin to see if that can throw more light on the matter? You may be able to identify if it’s just one brake that’s causing the problem.
Jeff
