noise from steering wheel
- Thread starter Guest
carlmthompson
If so I have the same noise - can't work out if it's coming from the steering column or further down. It only seems to happen when the cars warm, and only when I'm at parking speeds.
ORIGINAL: carlmthompson
Is this the noise that goes "whooooo". A bit like running two bits of plastic tube together violin style (or if anyone remember, those plastic tubes that you spun above your head as a kid!).
DITTO, it doesn't happen when cold - only when warm and of almost full to full lock on ?
A kind of hollow resonating whooo noise, i initially thought it might have been something rubbing as i needed a new ball joint on one side, but that's repaired now and it still does it on either diresction of steering at over 50% steering lock on ?
Would like to get this resolved as it is rather anoying and embarasing when parking in a busy place.
I am 100% confident it will be cured on my Turbo if I ditch the PAS though [
ORIGINAL: mik_ok
Car is in for service / MOT
Apparently my rubbing noise was the horn switch.
Interesting, and very cheap to fix too ;-)
