Noise from Steering!
- Thread starter Arran
ORIGINAL: Arran
My 02' Boxster S has a noise which is evident when turning or manoeuvering at slow speeds. Any ideas folks? The car has done 25k miles and is in good condition with a full service history ie well maintained.
NM
On delivery of my Boxster the sales rep told me that the car would make a noise on full steering lock and told me it was nothing to worry about.
In fact, there is a note about this in the Driver's manual. On p155 it states "The flow noise heard at full lock is design-related and does not indicate a defect in the steering system."
Maybe this is what you are hearing. Or is it also on partial lock that it is happening?
Steve Brookes
Moderator
My '01 S is at the OPC I bought it from a month ago to have a mechanical creek sorted when manouvering slowley (ie Parking) However a friend has the same and it tends only to happen in the hot dry weather.
I'll let you know the outcome, may be of interest to you?
Result, creak gone and the steering even feels a liitle lighter and more progressive even with 18's.
Mike
Now if someone could let me know how to lubricate the bell housing clutch piviot in situ, I could cure that final embassing hot temperature only squeak..........
Back from the OPC and they simpley greased the steering thingy and the dry creek now gone! However, as with Mic I now have a dry, warm weather only creek/squeek from the clutch. This I have been told is the Clutc release bearing and it is going back to have that done under warranty on Tuesday.
Hope that helps?
Richard.
