Someone has installed a tin can with gravel inside at the rear of my car...
About 5-10s after starting from cold I get a sound like a tin rolling with gravel in it, in two bursts of about 1/2s each. The sound seems to coincide with first the auxilliary equipment starting (i.e. Aircon) and second the fast idle choke coming off a bit: so it sounds when the revs drop to a certain point suggesting something is vibrating. As I move off (either forward or backward) and the revs drop again (tend not to use the gas, just the clutch in the garage and car parks) I hear the sound again, for longer this time, until the speed (revs) pick up. Once the engine is warm this doesn't happen at all, suggesting heat expansion stops the part vibrating.
Candidates are heat shield or exhaust. The noise is from right rear. If it was the heat shield, I would think you might get it with a warm but rested engine on restart (cold shield). So I'm thinking exhuast, possibly the Cat? Any other ideas?
