noise
- Thread starter Alvis10
When you turn off the A/C I assume that the pump will be turned off, so it sounds as though the noise could be related to that, although I don't know why you would still get some noise with the system turned off.
If the car's been standing idle for a while maybe it would be wise to get the system checked for leaks and recharged if necessary?
Jeff
Maybe something in the system has worked loose in the area around your glove box and rattles around or is touching something when the A/C is switched on and refrigerant is flowing?
Jeff
