Axl Rose
This topic has already been here but it faded away..guess i didn't know exactly how to describe it..but it seems to be getting worse..so i've been keeping my eye/ear on the problem and i'll give it another go..
When switching gears the noise appears just before the clutch pedal gets all the way back up..the noise is worse if releasing the pedal faster..it sounds like something is loose..like a piece of metal banging another..sometimes i can't get into reverse..i press the clutch but the gear doesn't go all the way in..so i need to switch back to neutral,release the clutch,press it again and i'm in reverse(although i'm not sure if that's releated to this problem as i've heard that it's pretty common on 944's)..
Just a few more things i didn't mention before..the noise also appears when pressing clutch somewhere in middle or bottom..and the moment i switch off the engine..
