Axl Rose
I've been experienceing noises from the front end for quite a while now..i was told that the reason is worn torque tube bearings..well..i've just replaced torque tube but it's still the same..the noises appear when pressing or releasing clutch and sometimes i have to press-release clutch more than once to get into reverse..
Has anyone had a same problem? Is it the clutch that needs servicing or is it the gearbox itself(although the noise seems to be coming from the front end)?
