A couple of things. There are no moving aircon parts in the front (well, there is the ventilation blower in the dash) but I don't suppose you mean that, the compressor is in the back mounted on top/side of the engine.
Secondly, I wouldn't use Kwik fit as I'm pretty sure all they do is plug in a can of aerosol refrigerant. Problem with that is if you have any moisture in the system the stuff they put in will potentially cause a blockage in the system (I was told of one guy who had to get a new, ah the part name escapes me, the bit where the liquid goes through the tiny hole becoming a gas a causing the temperature drop). Nothing against Kwikfit per se, getting my MOT at the local place at two.
Might be worth saying where you are in the country and get a rec for an aircon specialist. A visit/pressure test/suction/refill is usually only around £50, and if you get someome good they'll let you know if your system is functional before refilling it.
