I think BF is Space Grey. ([link=http://www.porscheclubgbforum.com/tm.asp?m=230691]http://www.porscheclubgbforum.com/tm.asp?m=230691[/link]) There isn't anything that you can do yourself to check the aircon. Being a new engine (assuming it was a Porsche exchange) it will have a new compressor, so I doubt that's at fault. The systems get noisy when the gas is low, so although you have had it re-gassed, I would get it checked again. Also, make sure they know the correct weight of refrigerant and oil to use.
Noisy Aircon
- Thread starter Richard_Hamilton
penfold944
Yeah - I thought so based on your colour codes... Actually, worth noting that on an exchange engine, Porsche do not provide a new compressor. The old one is taken off the existing engine. Everything else is provided - just not the compressor ! I suspect it is low gas - but I think I must have a leak somewhere as it shouldnt have gone down that quickly.... the OPC regassed it FOC for me - so I would hope they know what they are doing
Thanks Alan
penfold944
Hi,
I'm having a problem with my AirCon.
I had it regassed recently, and failry shortly after, it started to get quite noisy. Not mad noisy, but louder than I would like.
Its still blowing hot/cold air as requested but its just noisy... Its not always that way - some days its fine.. I guess its down to how hard it has to work.
If I turn off the aircon so that when I start up, its on the min setting with the compressor running its whisper quiet.
It was making noise in fairness before I regassed it - but having had a few minor alterations done (like a new engine) it didnt work at all afterwards. Since been rectified, but now the noise is back again.
Do they need to be bled - or is there anyway I can check if its a pressure problem? I had a bit of a look at the rads from the intakes and they look ok to me.
Alan
p.s. - does anyone know what the interior colour BF is ????
Alan
Paul Fraser
The other place they leak is the lines -- the thick black metal ones -- that run down the right hand underside of the car, especially near the plastic brackets. Run a cloth along them and see if you get any greasy green fluid.
Especially if someone has badly placed a jack when lifting the car.ORIGINAL: Paul Fraser The other place they leak is the lines -- the thick black metal ones -- that run down the right hand underside of the car, especially near the plastic brackets. Run a cloth along them and see if you get any greasy green fluid.
penfold944
OK.. thats a few things to chase up.. Thanks for all that feedback. It is blowing cold air perfectly fine, but the gurgling noise does sound right.... I'll put it on my list of things to do
Thanks Alan
