robwright
As long as the tappet gap has remained unchanged then there should be no problem.  If the noise isn't going away when the car is warm then there is a problem with the oil feed to the tappets.  As said before oil can sludge up in engines when not used.  As a minimum I would suggets an oil and filter change - not too expensive and you should do it anyway after standing so long.  In fact I would change all my fluids.  If that doesn't help I would then get the rocker cover off and start investigating why your tappets aren't hydraulic anymore.
