ChasR
My 944 has bee quite dependable as of late. It is a good job really since it became a daily driver with me putting on more miles in 6 months than the car covered over 5 years.
However it seems it may have taken its toll. A short while ago now and again on rare occasions (it used to do it more when cold ) the car will idle OK (if I am honest, it would stumble a bit more, and hunt slightly), yet when it came to revving the car it would not rev beyond 2krpm. This would soon clear itself with business returning to normal (idle is generally very steady on this car, and it pulls well), although sometimes it would idle at closer to 2000rpm for a short period of time before settling back to its normal idle within 15 seconds or so.
Today this problem came back to haunt me twice, but regardles of engine temperature. This time the car was barely idling, with revving it causing no change in RPM but for it to attempt to cut out, and at one point it did just stumble and die. I restarted it and within seconds the issue went away. When it was close to dying with no throttle I noticed that the boost gauge went close to 1 bar, indicating that very little vacuum was present (at idle it tends to set at or lower than 0.4 IIRC).
I was thinking along the lines of AFM or TPS, but I cannot see how it would tie in with a change in vacuum.
What are your thoughts? There seem to be no vacuum leaks present, although I guess you never know.
