1987 Model Carrera won't start. Starter Motor is turning the engine over. I am working through troubleshooting steps outlined in Bentley Manual .
History of the problem was I had the car off the road and every couple of weeks I would start it up to keep it running , then after a couple of months it failed to start.
Inspection of the Distributor found marked points and some signs of tracking etc, so I ordered a new rotor and distributor , and DME relay to boot. After installing these no change. No start
I have identified a problem with open circuit on spark plug lead number 3, I will order a new one, however I would not have thought one faulty cable would have prevented the engine from starting.
I have tested the speed and reference sensor which are fine, and the solenoid is within spec.
I will continue to trouble shoot. If anyone has experienced a similar foot print I would be grateful for any advice .
Brian
Brian
