Any ideas what the issue is here:
Having used my car very little for over 3 years, this past weekend I did more miles than in those 3 years - wow it was fantastic!
Started perfectly last week and over weekend until Sunday morning, then completely unexpectedly, I went to start it up and "click" from the rear then nothing - no turning of engine.
I looked around for what I must have left switched on overnight - but nothing. Tried again. Nothing except the click.
I checked the battery voltage - 12.3 volts. That's not great, but plenty to turn it over. Connected my jump-starter and left it for a few minutes. Tried again and nothing except the click.
So I wondered if the starter motor was jammed. Pushed it forward and put it in gear to jog the engine a little. Then it was happy to start immediately with no sign of any battery sluggishness. So assumed problem was a starter lock up.
I let it run for a few minutes and switched off. Came back in an hour and tried to start - again just a click. Tried again only 5 seconds later and immediately started. Drove 100 miles including a couple of stops and no problems.
Left it parked in my garage until today (Wednesday) and went to do some investigation. It started immediately on first turn of key so not much investigation to do. Drove out of garage and around to house. Switched off. Came back 5 minutes later. Nothing except a click!! Tried again 5 seconds later and it started up just fine. Drove for 30 miles with a couple of stops - restarted fine each time.
So what could the cause be? Is this maybe the "DME relay problem"? I swapped the DME relay some years ago having heard about the problems with the original - so the current one is not the car's original. But maybe they deteriorate?
All ideas welcome. Thanks
