Non working headlamp washers
sturman
What is the most likely cause of the above please and how does one go about rectifying it ?
Thank you.
Richard.
If the fuses and relay are OK (the list is on the lid of the fuse box), you should take out the passenger side headlight (just flip the lever inside the luggage compartment and it simply pulls out), and you will see the pump - check the connections. Worked for me. When testing, note that the headlights have to be on main beam or the washer will not work.
I have same issue on my car, troubleshooting proved the relay at fault. An expensive item at 45 pounds to wash your headlights.
No, but if I was into that, I'd probably chuck my MacDonalds drink and trash at them too (I've seen it done and had it chucked out of the car in front of me, too). Damn ignorant [:mad:].
Er, sorry about the rant. It is a very annoying, though.
