Norsdschleife 944s in a Fail Compilation
- Thread starter 944 man
Indi9xx
Interesting that both of them lost it in exactly the same way and hit almost exactly the same bit of armco.
I also wonder how many times the Nurburgring get to charge different people for the same bit of armco before they actually change it, or how badly it needs to be damaged before they charge you.
Whats the latest with the Nurburgring anyway? Not heard much of the "save the ring" stuff in the last couple of months.
edh
ORIGINAL: 944 man
I suspect that Eds guess is far more accurate than mine. Ive just looked again and I can now see that the cars are heading uphill.
The only thing that I can't see is the rumble strip that you run over on the exit of Eiskurve - maybe it's a bit further up the hill? Very hard corner, people turn in too early I think
chrisg
This would explain why the cars are going so fast and have so much momentum as they swing through the left hander before oversteering off ! It's very easy to unsettle the car as you come over the crest at SchX and then the car is unsettled.
Chris
edh
I know you can spectate at the spot after SX - here's a vid taken from just a bit close to the bend.
http://www.youtube.com/watch?v=B_t2xskn5yE
Definitely a corner to have something in reserve....and some throttle on to keep the back end planted
http://www.youtube.com/watch?v=Zxg2whz9mL8
caught this one though
http://www.youtube.com/watch?v=MXxO84tJl04
you can see from the second of those spins - I was probably only doing about 40. It is very very slippery there when its wet..
944 man
ORIGINAL: 944 man
My guess is that it is Schwedenkreuz, the last left before Aremberg. The downfall of many a young Jack.
Simon! [
