Not a Porsche
- Thread starter berg944
Mike
pauljmcnulty
From standing start, he launched down the Swindon sliproad onto the M4, and didn't stop until the little red numbers had stopped flashing. The fastest I've ever been on the ground by some margin. Of course, there aren't many corners on the M4 [
PS, I wouldn't mind Diplomatic Immunity, either....[8|]
Neil Haughey
berg944
LS1 Engine - 350 BHP
1470 Kilo
First car I have had with a DIC !!!!
The Driver Information Centre (DIC) shows just about everything digitally. Tyre Pressures, Oil Temp, G/Box Temp etc. It tells you any, I do mean any problems...........misfire on a cylinder.....fuel mixture.
If say the ABS did not function as it should it will tell you to check ABS. No need to plug in a laptop just press a couple of buttons and it will give you a code that tells you have a O/S Rear sensor needs replacing. It has over 300 codes and stores the history so you can check the frequency of intermittent faults.
Excellent Bose Hi Fi with 4 huge speakers
Dual A/C
Very comfortable to drive.
Interior a bit plastic.
Roof comes off (Targa)
Only service to do on the engine for the first 100k is oil/filter and Air Filter changes, after that you need a coolant change!!!
Security that good they sometimes refuse to unlock the steering......under any circumstances (a recall was issued to solve this)
Almost forgot to mention the Head Up Display (HUD) projected onto the windscreen like a jet fighter!!!
Has Traction and stability control.........not brave enough to switch it off......or rich enough as I think it would waist the new £500 rear tyres in minutes.
Mike
Hilux
Its nice to see that people who appreciate cars dont migrate entirely from forums that were due to their previous love/hate relationships with a car.
So many times you see and read " .................after ten years on this forum its goodbye from me as I`ve bought something different"...............why?
Why not stay on all forums (as I do) [
mik_ok
Hear hear. [8D]
I also don't want to appear to be a newbie when I finally collect my 997.1 GT3. One day (sigh).
berg944
All yank cars are unable to go around corners, apparently !
Thats what I thought, pushed it a little bit the other day and was very surprised.
It does not learn over like I thought it would but it does have the sports suspension pack.
Its similar weight to a Turbo (sunroof models) but the centre of gravity is alot lower. Wings, Hood[
First corvette to have a transaxle so near 50/50 balance.
Lots of rubber 275-18 rear, 245-14 front
Suspension is very light as the springs run horizontal under the car and are made of..........Plastic (I also didn't believe it)
I have never seen one on the track so you could be correct from a racing point of view.
Mike
