Not another question about ABS? Afraid so!
jonnyporsche
Help please, is there an easy way to tell if the rear stub axle has an abs ring or not without removing the abs sensor.
Look down the side of the CV joint with a torch and see if it has square teeth beyond it.. Not easy to see, but you should see them.
Pal of mine seemed to have raced without his ABS it has since transpired! Dangerous to say the least ....
