Hoopster
During the wonderful PCGB Factory Tour trip around Germany, (which I can heartily recommend!) I began noticing mild vibrations in the "lower back" region at around 3500 rpm in each gear. Just before the trip my OPC had done a full fine balance on each wheel and a full geometry set up too, so I am pretty sure it was not related to the wheels or geo.
Today I had an opportunity to take the OPC engineer out for a test drive, to experience the vibrations for himself. He indicated that he thought the cause could be a slight imbalance of a gearbox/engine component e.g. clutch, flywheel...? We also noticed that when the car was at standstill (in neutral) and the drive was not under load, the vibrations occurred around the 2500 rpm mark.
In order to further diagnose, the OPC would now like test for vibrations with the gearbox attached and unattached, thereby hopefully being able to identify if it is clutch related or something else in the engine (flywheel?)
To drop out and test with/without gearbox is a considerable expense, which may or may not be covered by the warranty depending on the outcome (a clutch replacement is wear and tear, an imbalance in the fly wheel would be a fault and thus a warranty claim.)
So I am trying to figure out my risk/reward sum here and would welcome any suggestions & thoughts.
It's a 2007 987 3.4 S, mileage is 36000 (ish).
Does the fact it vibrates in neutral at standstill indicate the likehood that it is not clutch related ?
At what mileages do clutches need replacing ? I do realize this is heavily dependent on driving style, but it is a lightly used car, and I have yet to wear out a clutch on any other vehicle I have owned in 30 years, so 36k feels a bit early.
HAs anyone else experienced mild vibrations as a precursor to a worn clutch ?
I would expect that a flywheel imbalance is not something that develops over time - surely it's either there or it's not from the start?
Your insight and wisdom would be much appreciated !
Adam
Adam
