Timbo2
Finally got round to looking underneath the car, went up on ramps a treat. Noticed what I thought was a potential RMS leak turned out to be weepy drivers side oil seal on the axle shaft. I'm assuming it has it's own oil supply, does anyone know how to check the level. Also thought this might account for the smell that I sometimes notice as its close to the exhaust. Also spotted a loose heat sheild, one of the fasteners was rusted away, and a bolt on the exhaust flange had snapped off. After about an hour and several drill bits latter I managed to drill out the remains and replace the bolt. So that was saturday! Thought I might take a look at the plugs, do I just remove the allen bolts that secure the coil and disconnect the wires? What size are the plugs, anything else I shouls know befor I do this. Finally, adjusted the handbrake last night, spot on now just 3-4 clicks, thanks to those who gave me advice on that.
