While i was fitting a new ignition switch/steering lock,i unpluged two electric plugs that run through the bulkhead by the back of the ignition switch.I need a big favour from someone!:
Can someone look under their dashboard by the ignition switch.There will be two rubber type plugs,one either side of the ignition switch.One has got a larger cap on it than the other.Can someone tell me what side the larger plug goes.
Thanks for any help!
Andrew.
Andrew.
