Not using the 911 for the winter.
- Thread starter andyslade
Mine spends quite a lot of time in the garage over the winter, but at least once a month I take it out for a good very long run.
If you want to lock it away for several months then I'm told you need to prepare for such a hibernation - car cover, battery trickler, depress the clutch, etc etc, I'm sure the other have a full list of do's and don'ts
Helen Goff
No.1 Poster
give them a good wash,dry and then tuck them back up in the nice warm garage with trickle charger plugged in.
944 get used all the time what ever the weather [8D]
I make sure that the car gets a good run at least once a month but only when its dry and the roads are free of the dreaded salt!
If the car stands still for too long it can be worse for it long term than using it in the bad weather - get loads of quality wax on the car ( I use swissol) and that too will help protect it.
Adam
adamtsobek
I had similar problems with flat batteries until I bought one, now even after 2 or 3 weeks with out use it starts first time; wouldn't be without it
I also use a dehumidifier after taking the car out for a run in wet weather, a couple of days usually dries it out fully. It should be noted that a well sealed garage is essential
It is really good much better than the first one I had.
I've got one too and it works very well!
Roy
Marc
911addict
911's are such a pleasure to drive that I have to drive mine EVERY day, whatever the season!! Regular maintenance and occasional body attention over the years (I don't think you can ever avoid this with a 10 year+ old car) have always ensured mine stay in great condition.
