Notchy Gear Change
- Thread starter marty
petrolhead944
George Elliott
I would start with the "knuckle" in the linkage - located above the driveshaft on the passenger side of the gearbox.
Take the N/S/R wheel off to access it.
It is not a 5 minute job to DIY, - but it may be dry and getting tight due to exhaust heat and lack of grease. It needs to be dismantled to clean / grease properly. I emptied a can of WD40 over one without effect.
There may be other causes but this is an easy common one
Good luck
George
944T
964
The gearbox oil was replaced about 5 or 6 years ago, I think it was with synthetic oil.
Should it need changing again?
I don't know if the linkage has been lubricated as I don't service the car myself.
Would this be done as part of a 12000 mile service?
Is it common for these joints to need replacing?
Diver944
ORIGINAL: marty
No it wouldn't be done as part of a service. The gear oil has a service interval of 4 years so yours is well overdue a change. As 944 gearboxes are prone to noise and expensive to rebuild I change mine every 2 years as preventative maintenance.
It's not comon for these joints to need replacing but it is a moving part that is exposed to crud and after 20 years I would expect to repllace it. A genuine linkage is circa £120, but there are aftermarket short shift versions from about £50
You mentioned short shift kits there and it's something I had been thinking about as I have always thought the throw is too long.
There are kits for both the front and back ends advertised ( Porscheshop do both), which do you think is better and do you have any opinion on who's is best?
George Elliott
I was going to comment to Paul that with 3.2 litres of torque - the gearbox is likely to be prone to noise ! []
George
944t
964
Diver944
ORIGINAL: marty
My personal view is that a new standard shifter at the rear is the best option. I had one a few years ago on my S2 and it is sooo sweet and light [] compared to the old worn out one. I have the roadshifter on my Turbo and it doesn't suit me at all, I will change it to a standard one at some point in the future.
