Hi any one had a problem with notchy gear change on six speed gear box just a bit stiff! 40,000 miles.
Notchy Gear change
- Thread starter bernard tester
Black80XSA
1st to 2nd on a cold gearbox is fairly common - anything else, or poor gear selection might need adjustment of the change linkage/cable (not covered by warranty)
Is the clutch the original one? It may be dragging slightly if it is on the way out, which can cause the shift to be notchy, and make it difficult to select first. David is right about 1st-2nd when cold, and linkage adjustment - that's fairly typical.
