O/S DOOR WIND NOISE
muppet
When I drive over 60!, I get quite a bit of wind noise on the O/S window around the door mirror Ive had a good look at the rubber it looks OK the same as the N/S,any ideas,Thanks Andy
Unusual for wind noise around the door mirror area. It is usually more along the top edge towards the rear. There was a thread about it recently here: http://www.porscheclubgbforum.com/tm.asp?m=522499
Perhaps the window isn't aligned quite right. I would check the gaps along the edges to see if they are consistent, and the same on both sides. I have some instructions for adjustments, but I found it quite a bit of faffing around to get it right. email me if you would like a copy.
Richard, could you please email me the instructions? I also have wind noise around the top of the triangle near the mirror. It appears the window is slightly lower in that area than at the top and rear. Looks like I need to adjust the front up a little.
Greg
