OBC
- Thread starter Rickster
GreenThing
Chris
Has anyone successfully retrofitted OBC on a 2003 2.7 986 ?
I like to be able to display fuel economy (MPG), saves me calculating it after each fuel up each week.
The MPG is a good indication of any problems with the car you may have.
Outside temp is also useful in the winter, so you can keep your speed down when the roads freezing...
b) Can the Durametric tool be used to enable the OBC option ? [
Here a few sites with info on enabling the OBC:
INSTALLING TRIP COMPUTER FOR 986 from PCA
http://www.pca.org/tech/tech_qa_question.asp?id={FC83CE49-9766-48D9-AD9A-B79980832239}
Good site with OBC Hack page
http://www.brackenrig.net/OBC_Hack.htm
Regards,
Chris.
b) No
If you want instructions for fitting OBC I have a DIY I prepared myself - contains instructions, parts lists, and coding info. Send me an email and I'll attach it to a reply You might also want to take a look here for some background info: http://www.porscheclubgbforum.com/fb.asp?m=231176.
Tool Pants
non Club member but v. knowledgable
The dot matrix cluster started in 2002. You only got the dot matrix display if the car came with the OBC option. The dot matrix cluster is different than a non OBC cluster. If you want a dot matrix cluster then you need to buy it and put it in.
It will be difficult to find an OPC to turn on the OBC on a 2001-2004, as they will say it cannot be done like it was on 1997-2000. That is when you make friends with Richard as he knows how to do it and has done it.
