Octane Boosters
- Thread starter gaxor
However I did ask at my OPC is using super unleaded would give any improvement, but they said just run the car on 95 octane fuel. You can put more expensive higher octane fuel in (similar to adding a booster) but the engine management is set for 95.
Adding a booster can lead to pinking or timing issues, but the engine management system adjusts for this. Therefore you get no advantage.
On a Nissan 200SX I tried this, but the higher octane seemed to give a bit more mid range but less top end power, presumably due to the timing change from the management system.
I don' t think it can do any harm so you could try it, although it might run a few degrees warmer.
On the Paris-Dakar they run cars on aviation fuel which is 110 or something.
Stuart.
