pauljmcnulty
Ok, VJ is due for her annual physical shortly so it can wait, but tonight I've had 2 strange electrical faults.
Firstly, the fan stays on. Sure, I know it's the sensor in the rad and it happened before back in the Spring, but I pulled the relay to stop it and it was very hot. Not too hot to handle, but I guess as hot as a domestic radiator. Is it worth changing it before trying anything more complicated?
More frightening, on an unlit country road at "entertaining" speed, I pushed the indicator stalk forward for full beam. And all the lights went out. [] The full beam came on after about a second, but there were some mutterings from the passenger seat! Pulling it back is fine, and after several goes (I guess a dozen on'off cycles over a few miles) it seemed to correct itself, or at least the "lights off" was almost intstant. It almost seemed as if there was moisture somewhere, and it dried itself out gradually, if that makes sense?
Any ideas? [&:]
Any ideas? [&:]
