Hi,
I purchased a new window regulator from Design911, specifically OE Match Classic Brand.
It fitted okie, etc 'but' here's the problem - no window drop on opening the door.
Micro-switches checked and working
Motor works and pulls the cable
Window doesn't drop
Goes up and down okie on normal operation (though it won't drop below the window rubber fully, sits about 1/2 cm proud when at lowest setting)
Has anyone else dealt with this brand and had similar, or any tricks/differences from the original that we may have overlooked?
Tried the 'zip tie fix' with no result - which would have been very annoying if it did because that would have meant a stretched cable out of the box
Thinking I might just rebuild the old regulator and return the new one as defective (frayed cable noted on old regulator, which prompted replacement even though it was working fine)
Cheers![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Window doesn't drop
