Fat Albert
Have had an issue of fluid dripping onto the exhaust and causing smoke recently, I have seen water dripping from the pipe that runs alongside the cam cover, where the rubber bit joins the metal pipe, but the smoke looks/smells more oily.
I have noticed that the heater hasn't been working well for the past couple of mornings, which aroused my suspicions around the cooling system.
Then this morning the car warmed up very quickly (ie the temp gauge not the heater), then when sat in traffic the temp gauge was going right up, but dropping immediately that I started moving The car was not smoking at all in traffic which is unusual! When I got to the station the expansion tank looked empty and there was water dripping out of the pipe by the exhaust at a fair rate with some of the smoke appearing... My thoughts are that either: The smoke is from the water dripping out of the pipe and it has got worse and the cooling system is a little low The smoke is from a head gasket oil leak that has decided to get worse and leak into the cooling system I hope that it is the first, my plan is to drive to the nearest garage tonight and fill up with water, go to Halfords and buy some new jubilee clips. If the car behaves normally tonight, I will use it tomorrow and just keep the water topped up, if not tonight (or on Saturday if it does) take that pipe completely off, clean the metal part that it fits over and apply some PTFE tape and then re-fit using the best sized jubilee clip. If the pipe looks perished I will order a new one (looking up the part no. On my CD this time!) If this cures the smoke issue then I will be very happy and annoyed at the same time (happy not to have to change the head gasket, and annoyed that I spent £500 having the cam cover gasket replaced!)
