Does anybody have the OE mats for an oval dash 944? If so, how well would you rate the fitting of the driver's side and would you mind showing a picture of it, particularly by the transmission tunnel and pedal areas and where the fixing points are? A pic of it out the car would be awesome too!
I bought a set from a supplier and they kinda fit but not very well.. the driver's side is too wide so it curls up the transmission tunnel about 1-2cm and the mounting points are off - they are too close to the seat rails so the metal mountings with the clip extend out too far. I'm trying to find out if they are all like this (in which case I will probably live with it) or if I've somehow got a dodgy batch.
Thanks!
Thanks!
