Oil change (Where to get filter/gaskets)
- Thread starter Guest
Evil J Guano
Try Mark at Roger Bray 01404 822 005
I would but a few filters as you should be changing them every 4000m along with the oil.
Oil: Castrol 10w 40 for Normal engines, not synthetic or semi.
The Knecht OX 79 filter comes with a gasket, I remove the 'handle' to use next time.
I think the Fram equivlelent is a C3
Should be all you need, if you want to clean the magnet and screen you will need two sump gaskets too.
Should cost you no more than £50 for oil, gaskets, filter and postage... hopefully
If you are doing a proper job do the valves too, then add rocker gaskets to your list.
Oil change: engine hot
Valves: engine cold
When you get up to speed 30mins should do it!
G
