No, an oill change wouldn't normally be required for a clutch change.
oil change
- Thread starter Richard_Hamilton
devans
This might be a silly question but here goes.
I had a new clutch fitted recently at my indie. To do this, would they have had to do an oil and filter change or am I way off track here. The only reason I ask is that i thought i would do an oil change tomorrow whilst Mobil 1 is on offer.
thanks
thanks
I think a magnetic plug is a useful thing to fit. The LN one gets good press. Better still if it incorporated a chip detector, but that's another story..........
devans
Arrrrrgh! What should be the easiest job I have ever had to do is turning into a nightmare. Being clever, (so i thought!) and only eight miles from euro........ i thought getting parts for my oil change would be easy. I was specific around the oil filter being hengst, recommended. However didn't have 76 mmx14 flute oil filter removal tool. Didn't have Mobil 1 oil and didn't have sump plug washer. Left it till following weekend and got oil from Hal..... On 20% off, 10 litres. Thought the washer would be easy to find. No such luck. Decided then to order washer from euro........ Which arrived today. As the sun was shining I decided to get under the car as I see this as a 1 hour job allowing for the oil to drain. DISASTER... Went to put the 8mm Allen key in the sump plug and the plug is completely rounded. Wish I had took it to the garage now. lesson learnt is not to travel to euro........, just order online in advance However, have any of you techno wizards got any idea as to how I release this plug which I believe would have been tightened to 37 ft lbs. much appreciated.
chriscoates81
Have you got any screw extractors? These look a bit like a backwards drill. There is also a tool that has 2 cutting faces which looks a bit like a counter borer. Or if your lucky you might be able to get a torx bit as they have a bit of a taper on them and in an electric drill might 'cut' in enough to loosen.ORIGINAL: devans Arrrrrgh! What should be the easiest job I have ever had to do is turning into a nightmare. Being clever, (so i thought!) and only eight miles from euro........ i thought getting parts for my oil change would be easy. I was specific around the oil filter being hengst, recommended. However didn't have 76 mmx14 flute oil filter removal tool. Didn't have Mobil 1 oil and didn't have sump plug washer. Left it till following weekend and got oil from Hal..... On 20% off, 10 litres. Thought the washer would be easy to find. No such luck. Decided then to order washer from euro........ Which arrived today. As the sun was shining I decided to get under the car as I see this as a 1 hour job allowing for the oil to drain. DISASTER... Went to put the 8mm Allen key in the sump plug and the plug is completely rounded. Wish I had took it to the garage now. lesson learnt is not to travel to euro........, just order online in advance However, have any of you techno wizards got any idea as to how I release this plug which I believe would have been tightened to 37 ft lbs. much appreciated.
devans
Thanks for all the advice. Job now done. Lack of specialist tools meant I had to carefully chisel out a channel on the plug which I was then able to ease with some gentle tapping of a screwdriver in the slot. Messy business oil changes. However, nine litres of Mobil 1 0/40 now in its rightful place.
