IanHighfield
Just a quick query regarding oil consumption, or in my case, a lack of it. I keep a regular eye on the level (hot engine at idle, oil level is between the two marks on the dip stick as per manuual) in my 86 Coupe, and have only just needed to add one litre of oil after nearly 6,000 miles. This seems at odds with the 1 litre per 1,000 miles that others quote. Should the engine be using more oil ? I had the return pipe and cam return pipes replaced at PCT and the car has no oil leaks, and blows no smoke. Odd to ask if it should use more oil, but just curious.
