Tommys86
Back from holiday and ready to take on the challenge of changing oil cooler seals... not quite, deep relaxation into complete nightmare.
I'm stuck and need some advice, got all the underside off, removed PS pump pivot points, oil filter off and struggling with the last bolt on the heat shield however that's not the biggest issue. Clarks garage is my guide but I fall to see how I can whip off an external cooler lines without A. a massive wrench not sure on size and B. Room to wave z wrench around. It's so tight I get on the 24mm oil sender unit and my wrench instantly fouls the ARB!
My plan is to skip these stages, 'go for glory' and remove 4 bolts for cooler and the also remove the oil cooler rad complete with lines but unsure how successful /possible this is? Obviously slacken manifold and remove oil pressure relief valve as per normal instructions but I simply can't get on the linew or oil sender unit in situ!
Or have I balls this up somewhere earlier on?
