al@broadway
I recently changed the flexible pipes on the oil cooler of my 1987 3.2 Coupe, in so doing I had to remove the oil cooler and drain it. I noted that the oil was looking 'well-used' as compared to the oil in the engine which is new. It occurs to me that in a normal oil change the cooler will not drain, but of more concern is that it appears that the new engine oil, changed 1000 miles ago is not circulating the cooler.
Is this normal, does the oil only circulate the cooler when it reaches a certain working temp?
Should I have replaced oil in cooler as I was relying on the pump to replenish and I would top up accordingly in the normal filler.
Perplexed Alan
Perplexed Alan
![A74F126A3897449BA854DD6C69E612B0.jpg](https://www.porscheclubgb.com/forum/legacymedia/upfiles/10461/A74F126A3897449BA854DD6C69E612B0.jpg)
