oil in water 944
- Thread starter Guest
Diver944
You're right, the pressure at idle when warm should be around 3 bar.
Which 944 have you got?
The high pressure could be a sticking oil pressure relief valve, or maybe (hopefully) a faulty presure sender.
Water in oil could be a leak at the oil cooler getting into the water, or of course the dreaded head gasket failure [:-]
Tony
