I have a 1985 944 which has recently began to seep oil into the cooling water. After prolonged use the oil level can be seen to reduce. There is no water seeping into the oil. From what I've read, I believe this could be due to one of two problems. The first being the head-gasket or, the second, a faulty oil cooler/leaking seals.
I'd be grateful if any of you guys (or gals) have any experience of this the past and any tips on pinpointing the most likely cause.
Many thanks
Ieuan.
