Oil indicator warning message
- Thread starter Pieman7
The sensor is on the right hand cylinder head, about half way back, pointing vertically upwards. You can access it from the top, but it is a bit buried. If you search the forum, you should find a photo.
Edit: Here you go:
https://www.porscheclubgb.com/forum/tm.aspx?m=513943#516036
Edit 2: Here is a better photo:
Also, if it's a faulty sensor - any ideas on price to get it replaced?
I'll give them a clean tomorrow and see how it goes. I'll also probably order a replacement anyway as it will probably need changing at some point.
Thanks again.
