Oil leak problems!
Hoops
Hi all,
My 2005 997 C4S has recently had a full engine rebuild. Since then it’s been back a couple of times; once for a solenoid replacement and then again to have some coolant pipes replaced Due to a small leak.
When I took it last time I mentioned an oil leak on my garage floor just after I topped it up. Fresh oil, golden in colour. only a small bit, maybe half a teaspoon or less
The garage checked it over and could not recreate the leak.
This morning I’ve just topped it up again and found a similar amount of oil, fresh oil on the floor.
I’ve not used the car too much, once a week at weekends but driven for 100 or miles each time.
Does anyone have any ideas what this could be? I’m at a total loss!
Any advice appreciated!
Matt
Hi Matt
Did you check the floor prior to filling? If it was dry then the only logical explanation is a crack in the oil filling tube,
Good luck
Hi,
I've topped it up maybe twice with less than 500ml of oil in total.
I topped it up last weekend and reversed out the garage to find a small bit of fresh oil. Left it for a few hours and place a cardboard sheet under the car and not a drop was found on it.
Then took it out for an hour or so and when I finished put another piece of cardboard under the car again and it was totally dry.
Left it for a few more days and again bone dry!
So its must be a crack in the filler tube?
Matt
Matt
You should be able to see any oil spill in the vicinity of the tube area. It's a DIY job part is about £48 from Porsche
good luck
Ok thanks all! Big help.
I haven’t seen some videos on that but looks like I need to remove the timing belt....?
thanks Matt
