sawood12
I have a minorish (approx 1000 - 1500 mile top up interval) oil leak somewhere. I've been trying to track it down but lack of obvious signs are hampering my efforts and it doesn't help when the oil gets blown about all over the place by turbulent underbonnet airflow. Several steam cleans and periodic checks have failed to locate the offending seal.
I strongly suspect the oil cooler/oil pressure sender unit simply because this appears to be the next most likely candidate since camshaft/crankshaft/balanceshaft seals appear to be OK (front of engine is dry) and the engine is wetter on the oil cooler/oil pressure sensor side of the engine than anywhere else.
Has anyone any experience of leaks from this area and are the oil cooler gaskets a simple job to replace since i'm considering just replacing the gaskets anyway to see if it fixes the leak?
Once this, my tyres are sorted out and then my A/C recharged I will have ticked all the jobs on my 'things to fix' list!
Thanks.
Thanks.
